Inkplate 6 compatible battery specifications
Which of your battery products will fit in the Inkplate 6 enclosure? I need to know what will fit so I can source it from another supplier.
Originally submitted via email support on 24 September 2025. Migrated to the forum for community visibility.
The compatible battery is 1200 mAh with dimensions 59.5 x 36.5 x 5 mm / 2.3 x 1.4 x 0.2 inch. It uses a JST-PH-2mm connector. Make sure it’s a Li-Ion 3.7V battery for compatibility. Pay attention to battery polarity as it’s clearly marked on the PCB - some manufacturers use opposite polarity. See the documentation for more details:
