I fried my Inkplate by connecting the battery in reverse. Will this destroy the e-ink screen or is there a chance it only damaged the power/charging circuit and the screen itself or other components could still be salvaged?
Originally submitted via email support on 6 March 2021. Migrated to the forum for community visibility.
Most likely, just the power circuit is fried: battery charger, voltage regulator, auto-select circuit. If you want, I could provide you with part numbers for those if you are able to change them.
Are these components possible to hand solder? I have a good quality iron but not much experience working with small surface mount parts. I’m certainly willing to try though. If it is just the power supply that’s bad, can I supply power directly to the 3v3 pads on the board? How much current does it draw?
You can get THT 2.2uF, which is large enough to solder. If you can do SMD, there are plenty of options. Where can you most easily source parts from?
I can order from digikey.com.
