Inkplate 6 ESP32 upload fails with "Failed to connect" error on Windows 11
I keep getting the error “A fatal error occurred: Failed to connect to ESP32: No serial data received.” when trying to upload an example sketch with Arduino IDE on Windows 11. I uninstalled and reinstalled the CH340 drivers and it still doesn’t work. In Device Manager under Ports it shows up correctly as USB-SERIAL CH340 (COM16). I think it may be a hardware problem.
Originally submitted via email support on 31 March 2024. Migrated to the forum for community visibility.
Could you please try lowering the upload speed to 115200 in Arduino IDE in the Tools menu and then giving it a try? Make sure you’re using the correct Inkplate board definition for your board.
If that doesn’t work try Arduino IDE Legacy, available at https://www.arduino.cc/en/software. Install the board definitions as normal then try it.
