Do you have a pin map of all GPIO with analog/digital info and availability (internal and external)?
Originally submitted via email support on 7 June 2025. Migrated to the forum for community visibility.
You can cross-reference the schematic: Soldered-Inkplate-6-FLICK-hardware-design/OUTPUTS/V1.2.0/Soldered Inkplate 6 FLICK Schematics.pdf at main · SolderedElectronics/Soldered-Inkplate-6-FLICK-hardware-design · GitHub
Check the last page for the ESP32 pinout. Many of the pins are used for the e-Paper display. If you’re not using the SD card (via SPI pins), you can use IO13, IO12, and IO34. If you aren’t using the wake button you can change the on-board jumpers to use it as a GPIO instead.
Let me know how many pins you need and what for, and I can help with pin selection.
