Inkplate 6 Flick peripheral mode frontlight and partial refresh not working
I purchased an Inkplate 6 Flick ePaper display and want to use it in peripheral mode with a Raspberry Pi 5. I found the example program on Github (GitHub - SolderedElectronics/Inkplate-Peripheral-Mode-Raspberry-Pi-Example: Some example code for how to drive Inkplate with a Raspberry Pi using peripheral mode · GitHub) and the documentation (Inkplate Peripheral Mode — Inkplate docs documentation) with the necessary commands. I can get a basic display working, but I’m unable to enable the frontlight or perform a partial refresh. Can you help me with this? Perhaps with an example program that uses these functions?
Originally submitted via email support on 3 January 2025. Migrated to the forum for community visibility.
The peripheral mode example needs an update as it currently only provides limited functionality. These features may not have been fully tested. Try re-downloading the peripheral mode example for the 6FLICK. Pay attention to this code line in the example: the command is “m” as described in the documentation. Partial refresh should also work once the example has been recompiled and uploaded to the 6FLICK. Try again after re-uploading the example. If it still doesn’t work, you could try debugging the issue yourself. The frontlight functions appear to be correctly implemented. Let me know if you can get it working this way.
Original message (German)
vielen Dank für Ihre Nachricht. Ich verstehe Ihre Frage und bedaure, dass Sie diese Erfahrung gemacht haben. Das Peripheral-Mode-Beispiel benötigt ein Update, da es aktuell nur begrenzte Funktionen bietet. Es könnte daher sein, dass diese Funktion nicht vollständig getestet wurde.
Bitte laden Sie das Peripheral-Mode-Beispiel für das 6FLICK erneut hoch. Beachten Sie dabei diese Codezeile im Beispiel:
Codezeile ansehen
Diese Zeile zeigt an, dass der Befehl „m“ ist, wie in der Dokumentation beschrieben:
Zur Dokumentation
Die partielle Aktualisierung sollte ebenfalls funktionieren, sobald das Beispiel neu kompiliert und für das 6FLICK hochgeladen wurde.
Versuchen Sie es bitte erneut, nachdem Sie das Beispiel neu hochgeladen haben. Falls es weiterhin nicht funktioniert, könnten Sie versuchen, das Problem selbst zu debuggen. Die Frontlight-Funktionen scheinen jedoch korrekt implementiert zu sein.
Bitte lassen Sie mich wissen, ob Sie es auf diese Weise zum Laufen bringen können.
