Inkplate 6 MOTION MCP73831 configuration for third-party battery
I’m planning a project using the Inkplate 6 MOTION with frequent updates and long periods without charging. I need to use a larger capacity battery sourced from outside your store: ICR18650 10050mAh 3.7V.
Question 1: The MCP73831 battery charger on the Inkplate has configuration options. Will I need to change any of those for optimal use with this battery?
Question 2: Do you have any timeline for restocking the Inkplate 6 MOTION?
Originally submitted via email support on 28 December 2025. Migrated to the forum for community visibility.
The MCP73831 does not need to be changed for your battery. However, you can change the SMD resistor R38 on the board to a higher resistance value. This will slow down charging but will help preserve battery health over longer term use. The Inkplate 6 MOTION datasheet and KiCAD files are available to help you with this modification.
