I purchased an Inkplate 6 Plus and unfortunately the battery does not charge. I checked with an ammeter and confirmed that it draws power when the Li-Ion battery is connected, but does not provide power when USB is plugged in. After checking the board, the issue appears to be caused by the MCP73831T not being soldered correctly - it is soldered on pads below its intended position. I’ve attached a photo showing the problem.
Originally submitted via email support on 21 January 2022. Migrated to the forum for community visibility.
