I received my Inkplate 6 Plus and when I insert an SD card, the device crashes with Core panic errors. The screen flashes and I get these messages on the serial monitor. Without an SD card, everything works fine. I tested with 2 different SD cards formatted in FAT32.
The error output:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
rst:0x10 (RTCWDT_RTC_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load: ,len:10900
load: ,len:6360
entry 0x400806b4
SD Card OK! Reading image...
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400de286 PS : 0x00060d30 A0 : 0x800da3c3 A1 : 0x3ffcca60
A2 : 0x0000003f A3 : 0x000000ff A4 : 0x0000003f A5 :
A6 : A7 : 0x3ffcacc0 A8 : A9 :
A10 : A11 : A12 : A13 :
A14 : A15 : 0x3ffcacc0 SAR : 0x0000000a EXCCAUSE: 0x0000001c
EXCVADDR: LBEG : 0x4000c349 LEND : 0x4000c36b LCOUNT :
ELF file SHA256:
Backtrace: 0x400de286:0x3ffcca60 0x400da3c0:0x3ffcca80 0x400d6cf5:0x3ffccaa0 0x400d70a4:0x3ffccac0 0x400d599e:0x3ffccae0 0x400d41a0:0x3ffccb10 0x400d4212:0x3ffccb60 0x400d3bc9:0x3ffccbb0 0x400d2060:0x3ffccbe0 0x400df8e2:0x3ffccc10 0x4008aaea:0x3ffccc30
Rebooting...
rst:0xc (SW_CPU_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
load: ,len:10900
load: ,len:6360
entry 0x400806b4
A2 : 0x0000003f A3 : 0x000000ff A4 : 0x0000003f A5 : 0x000087c0
A6 : 0x000000ff A7 : 0x3ffcacc0 A8 : A9 :
ELF file SHA256:
Rebooting...
load: ,len:10900
load: ,len:6360
entry 0x400806b4
Originally submitted via email support on 7 January 2022. Migrated to the forum for community visibility.
