Inkplate 6 reboots after deep sleep with battery
I’ve been using an Inkplate 6 since December 2020 and recently ordered a battery. However, when I run the Inkplate with the battery, it reboots immediately after going to deep sleep. This appears to match the issue described at Unexpected behavior under battery only · Issue #56 · SolderedElectronics/Inkplate-Arduino-library · GitHub. How can I get a replacement?
Originally submitted via email support on 11 January 2022. Migrated to the forum for community visibility.
This is a known issue that affects some of the older Inkplate batches. Rather than shipping the board back and forth, would you be able to hand-solder a capacitor to fix it? Instructions and a reference image are available at https://camo.githubusercontent.com/c8c5187e12f00362f9be626d0a01a585da0eec4/e6a706567
I’ll give it a try. My soldering skills are a bit rusty, but I should be able to get the capacitor next week and attempt the repair.
Good luck! If you have any trouble finding the capacitor, let us know and we can help.
