Inkplate 6 v2 design changes and mechanical compatibility with v1
I’ve previously ordered a display from you and need a quote for 5 units of Inkplate 6. I hope nothing has changed in the design since I’ve already engineered and fabricated housings according to those specifications.
  • inkplate 6 x 5kom Nadam se da nije mjenjano ništa u dizajnu jer sam već projektirao i izradio kućišta prema tim specifikacijama. Hvala
Attachment omitted in migration: unnamed_attachment_1.jpeg
Originally submitted via email support on 4 April 2022. Migrated to the forum for community visibility.
We’re currently producing Inkplate 6 version two, which has some differences from the version you likely have. The main changes are the power switch, USB-C port instead of microUSB, and similar details. You’ll probably need to modify your housing somewhat. We can send more details if needed.
hvala na upitu. Vi vjerojatno imate Inkplate 6 verziju 1, dok sada proizvodimo verziju dva. Ima nekakvih razlika, prvenstveno u prekidaču za paljenje, USB-C port umjesto microUSB i takvi detalji. Morat ćete vjerojatno malo izmijeniti kučište. Možemo poslati više detalja ako bude trebalo.
The only parameters that matter to me are:
  1. Is the display size the same?
  2. Are the mounting holes the same dimensions?
  3. Has the serial protocol and communication changed?
We use these for parking terminals and we’ve already invested in designing the front panel and terminal hardware based on your information from last year that the design wouldn’t change drastically. Please send me the technical details of the dimensions.
  • jedini parametri koji su meni bitni su:
  1. da je ostala ista veličina displaya?
  2. da su rupe za pričvrščivanje istih dimenzija…?
  3. jeli se mjenjao serial protokol i komunikacija ?
Mi to korstimo za parkirališne terminale i sad smo uložili 7k eura u dizajn prednje ploče i terminala na osnovu vaših informacija od prošle godine kako se dizajn neće drastično mjenjati.?!
  • pošaljite mi tehničke detalje dimenzija
Hvala na razumjevanju.
The display size is the same. The mounting holes are the same. The serial protocol and communication are the same. You shouldn’t have problems with implementing the boards. These are all the changes from v1.0 to v2.3, which is currently being produced:
  • USB-C port instead of micro USB
  • Power switch is now in a form of a pushbutton
  • Wake-up/user-programmable LED
  • Power LED, can be turned off with an onboard switch
  • RTC onboard, based on PCF85063
  • better VCOM compatibility with panels
  • other DFM improvements
We’ll be posting the new open-source files from which you’ll be able to extract all the information. I can also check whether we might still have some old versions in stock that we could send you. We’ll let you know tomorrow.
veličina displeja je ista. Rupe za pričvrščivanje su iste. Serijski protokol i komunikacija su iste. Mislim da nećete imati problema s implementacijom ploča. Ovo su sve promjene iz v1.0. na v2.3. koja se trenutno proizvodi: - USB-C port instead od micro USB - Power switch is now in a form of a pushbutton - Wake-up/user-programmable LED - Power LED, can be turned off with an onboard switch - RTC onboard, based on PCF85063 - better VCOM compatibility with panels - other DFM improvements Tržište je takvo kakvo je pa smo sretni da uopće možemo proizvesti bilo kakvu verziju ploča. Postavit ćemo nove open-source datoteke iz kojih ćete moći izvući sve info. Javim sutra.
