I need the dimensions of the Inkplate 6COLOR to design a circuit board that it will plug into. Can you provide a picture with all the dimensions?
Originally submitted via email support on 3 November 2023. Migrated to the forum for community visibility.
The current Inkplate 6COLOR has dimensions of 131.5 x 105.5mm. Older versions have a larger PCB. If you need dimensions for the older Inkplate, let us know.
Attachment omitted in migration: Inkplate 6COLOR dimension.PNG
The dimensions you provided don’t match my board. I purchased mine about a year ago and there’s no version information printed on it. The board measures approximately 146mm x 116mm. I’ve attached pictures for reference.
Attachment omitted in migration: 20231107_075735.jpg
Attachment omitted in migration: 20231107_075820.jpg
That is the old version of the Inkplate 6COLOR. The dimensions are 145x116mm. The center of the mounting hole is 4mm from the edge of the PCB, and the hole diameter is 3.2mm.
Attachment omitted in migration: Inkplate 6COLORold dimension.png
