Inkplate 6Color library incompatibility with PlatformIO due to duplicate Expander definitions
The library doesn’t work with PlatformIO due to incompatibility of Expander. System.h has a problem with the definition:
#if defined(ARDUINO_INKPLATE10) || defined(ARDUINO_ESP32_DEV) || defined(ARDUINO_INKPLATE6PLUS)
#include "Mcp.h"
#endif
#if defined(ARDUINO_INKPLATE10V2) || defined(ARDUINO_INKPLATE6V2) || defined(ARDUINO_INKPLATE6PLUSV2) || \
defined(ARDUINO_INKPLATECOLOR) || defined(ARDUINO_INKPLATECOOL) || defined(ARDUINO_INKPLATE5) || \
defined(ARDUINO_INKPLATE5V2) || defined(ARDUINO_INKPLATE4) || defined(ARDUINO_INKPLATE7) || \
defined(ARDUINO_INKPLATE4TEMPERA) || defined(ARDUINO_INKPLATE6FLICK)
#include "Pcal.h"
#endif
Mcp.h and Pcal.h are both included and Expander is defined twice. Haven’t found a way to solve this.
Originally submitted via email support on 29 September 2025. Migrated to the forum for community visibility.
The Arduino library should work with PlatformIO as intended. You need to do this:
  1. Select ESP32 Arduino Core 2.0.14
In your platformio.ini, set the ESP32 platform to exactly 2.0.14, this one is used in the Inkplate library with Inkplate board definitions:
[env:inkplate]
platform = espressif32@6.9.0 ; maps to Arduino-ESP32 2.0.14
board = esp32dev ; or your Inkplate's base board
framework = arduino
platform = espressif32@6.9.0 pins the ESP32 Arduino Core to 2.0.14. PlatformIO Espressif32 release numbers map to Arduino core versions. 6.9.0 = 2.0.14
  1. Define ARDUINO_INKPLATECOLOR Globally
You don’t need to modify library headers. Just add a build flag:
[env:inkplate]
board = esp32dev
framework = arduino
; Pass a global macro definition
build_flags =
  -D ARDUINO_INKPLATECOLOR
This makes #ifdef ARDUINO_INKPLATECOLOR evaluate as true in all files during compile - this will make sure the library works.
