Inkplate 6COLOR power with 3 AA NiMH batteries instead of LiPo
I’m building a digital picture frame that downloads a picture via WiFi once a day and goes into deep sleep afterwards. I’d like to power the Inkplate 6COLOR with 3 AA NiMH batteries (1.2 Volts 2300 mAh) without charging them on the device - only using them as a power source.
I’m concerned about fire risk with LiPo batteries in a gifted device I won’t be able to monitor. My idea is to connect 3 AA NiMH batteries to the JST input of the MCP73831 charger with a Schottky diode to prevent accidentally charging while USB is plugged in. The batteries would only be charged with an external battery charger.
My calculations: a single Energizer NiMH AA-2300 mAh (HR6) provides up to 1.4V when fully charged and 1.2V on average. Using 3 AA in series would provide a max voltage of 4.2V and 3.6V on average. The MCP73831 is rated for an input of up to 6V according to its datasheet.
Would this work? Can I power the Inkplate safely this way? Is there anything I should be aware of?
Originally submitted via email support on 10 November 2022. Migrated to the forum for community visibility.
You can safely use this method with your batteries. If you remove the MCP charger you don’t need to use a Schottky diode. If you are going to remove the charger, please be careful when desoldering because temperature can easily damage the e-paper. Don’t use hot air for desoldering.
