Inkplate 6COLOR unable to upload sketch - serial connection failed
I’m unsuccessfully trying to upload sketches to an Inkplate 6 Color.
OS: Ubuntu 22.04
Arduino IDE: 2.3.6
Inkplate library: 10.0.0
The sketch compiles successfully but the upload fails with:
Sketch uses 953145 bytes (30%) of program storage space. Maximum is 3145728 bytes.
Global variables use 86324 bytes (26%) of dynamic memory, leaving 241356 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/ttyUSB0
Connecting………………………………..
A fatal error occurred: "Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
The device appears in lsusb output.
Originally submitted via email support on 23 May 2025. Migrated to the forum for community visibility.
I also tried pressing the I/O button on the side of the enclosure prior to upload, without success.
The error “Failed to connect to ESP32: No serial data received” indicates the board is powered off. The I/O button on the side is the power button. When Inkplate is powered on, the blue power LED should light up.
The correct procedure is:
  1. Plug Inkplate in via USB-C
  2. Press the Power button - the blue LED should light up
  3. The display should start refreshing with the default image from factory programming
Try these steps:
  1. Use a different USB port
  2. Try a different USB cable
  3. Check the LED power switch on the board - it should be set to 1 to turn on the power LED (this switch is configurable for low-power purposes)
If that doesn’t resolve it, try lowering the upload speed baud rate in the Arduino Tools menu to 112500.
After several button presses, the board powered on, the blue LED lit up, and I was able to upload a sketch successfully.
