I was working with an older Inkplate 6PLUS v1 display with a lithium battery connection. I charged it with a powerbank via USB-C while the display was running. The lithium battery expanded and looked dangerous, so I had to dispose of it.
I’m planning to buy new 6FLICK displays. Is charging via USB-C while running the display the intended way to use these boards, or should I charge the lithium battery externally and swap them out? Are there charging components on the board designed for this?
Originally submitted via email support on 20 November 2024. Migrated to the forum for community visibility.
