Inkplate 6PLUS missing MCP23017 IC
I received an Inkplate 6PLUS but found it is missing the MCP23017 IC. What part number do I need to order to complete the board?
Originally submitted via email support on 26 December 2023. Migrated to the forum for community visibility.
The part number for the missing IC is MCP23017T-E/SS
Can you confirm that if I solder the missing IC onto the board, the additional I/O functionality will be restored? Will any additional steps be needed?
Yes, if you solder the missing IC (MCP23017) the additional GPIO functionality will be restored. You don’t need any additional steps beyond using it in the code.
When soldering, be careful not to damage the e-paper panel with high temperatures. It is best to solder the IC using a soldering iron without using hot air.
