The file rbt_mic_logo.h contains a bitmap from the image converter and is in the same directory that I upload to the display. However, I get this error: 'bmp' was not declared in this scope (with suggested alternative: 'bcmp').
How do I correctly draw this bitmap on the display?
Originally submitted via email support on 6 September 2023. Migrated to the forum for community visibility.
The width and height must match the actual image dimensions. Also, make sure you’re converting the image in 1bit mode or 3bit mode according to your sketch - these produce different files.
