Inkplate forum account login not accepting registered username
My registered forum username is not being accepted when I try to log in. The error message says: You have specified an incorrect username.
Originally submitted via email support on 18 January 2022. Migrated to the forum for community visibility.
You can use custom fonts with the GFX library but only 7 bit ASCII, for all others you need to do modifications on the GFX library. On the link (Using Fonts | Adafruit GFX Graphics Library | Adafruit Learning System) is an example of how to add new fonts in the GFX library and use it with the library.
I agree, but that’s only the GFX’s limitation. The whole Inkplate lib is based on Adafruit GFX. The workaround is to make a custom font in ASCII with your characters - how does that sound?
Let us know if you do that, we could make some examples around it, it might be useful for others as well :slight_smile:
