Tested on the inkplate10 but I guess it is the same for all
I’m having difficulties rendering generated images
I’m using inker (GitHub - usetrmnl/inker: BYOS server written in TypeScript / React / Prisma · GitHub) to create some screens that I want to show on my inkplate and example of such a screen can be found here http://134.209.91.154/assets/default-screen-800x480.png?t=1785918118147
But I always get image open error, if I save the image and serve it via a the web it works fine (as I’ve read in the documentation)
Is there a way to get more information/pointers about the image format/specs so I can make sure the generated image is correct for inkplate to display or is there a way to make the inkplate library more robust so it can load these images?
The code I use
#include "WiFi.h" //Include library for WiFi
#include <WebServer.h> //Include WebServer library for ESP32
Inkplate display(INKPLATE_3BIT);
const char ssid[] = ""; // Your WiFi SSID
const char *password = ""; // Your WiFi password
WebServer server(80);
String prevValue = ""; // Stores the value submitted via the web form
String inputValue = ""; // Stores the value submitted via the web form
void handleRoot()
String html = "<!DOCTYPE html><html><body>"
"<h2>Inkplate Remote Control</h2>"
"<form method='POST' action='/set'>"
"<input type='text' name='value' placeholder='Enter value' style='font-size:1.2em;padding:6px;'>"
"<button type='submit' style='font-size:1.2em;padding:6px 12px;margin-left:8px;'>Set</button>"
"</form>"
"<p>Current value: <strong>" + inputValue + "</strong></p>"
"</body></html>";
server.send(200, "text/html", html);
void handleSet()
if (server.hasArg("value"))
inputValue = server.arg("value");
Serial.print("Input value set to: ");
Serial.println(inputValue);
// Redirect back to the main page
server.sendHeader("Location", "/");
server.send(303);
void setup()
Serial.begin(115200);
display.print("Connecting to WiFi...");
display.partialUpdate();
// Connect to the WiFi network.
WiFi.mode(WIFI_MODE_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(500);
display.print(".");
display.println("\nWiFi OK! IP: " + WiFi.localIP().toString());
delay(3000);
if (!display.image.draw("http://134.209.91.154/assets/default-screen-800x480.png?t=1785918118147", 0, 0, false, true))
display.println("Image open error");
display.display();
display.display();
server.on("/", HTTP_GET, handleRoot);
server.on("/set", HTTP_POST, handleSet);
server.begin();
Serial.print("Web server started at http://");
Serial.println(WiFi.localIP());
void loop()
server.handleClient();
if (prevValue != inputValue) {
display.println("New value received updating screen...");
delay(1000);
if (!display.image.draw(inputValue, 0, 0, false, true))
display.display();
display.display();
prevValue = inputValue;
