I want to ask if you can document the parameters of partialUpdate(). In your example Inkplate_Partial_Update_With_Deep_Sleep.ino it has two parameters, which are not documented in the API.
Originally submitted via email support on 27 December 2021. Migrated to the forum for community visibility.
You can find the docs here for that function: Inkplate Arduino — Inkplate docs documentation
In this documentation partialUpdate() has no parameters. But in your example code of Inkplate_Partial_Update_With_Deep_Sleep.ino it has:
display.partialUpdate(false, true);
There is a contradiction between your documentation and your sample code.
The first parameter in function display.partialUpdate(false, true) provides a partial update after boot. If you set this to false, Inkplate will make a full refresh the first time after boot. If you want to make a partial update after boot you must set this parameter to true. The second parameter is for the power supply for e-paper. When set to true, the e-paper power supply stays on after refreshing.
