Inkplate replacement screen adhesive requirements
I received a replacement screen for my Inkplate e-reader and need to know about the glue required. Does the adhesive tape need to have certain qualities, or would any double-sided tape work?
Originally submitted via the contact form on soldered.com on 18 December 2023. Migrated to the forum for community visibility.
For the tape, TESA double-sided tape is used. You can use any other double-sided tape with similar specifications, but the tape must be thinner so you can place the Inkplate in the case after gluing the e-paper to the PCB.
