Inkplate RTC resets to preset time after power cycle
I’m running the RTC simple code on an Inkplate with a coin battery. Every time I turn it off and turn it back on, the time resets and starts from the preset time instead of continuing from where it left off. I thought the backup coin battery was supposed to keep the time running regardless of power state. Is the RTC working as it should?
Originally submitted via email support on 17 November 2023. Migrated to the forum for community visibility.
This sounds like a software issue where the time is being set explicitly every time the device turns on. Check the example RTC_Alarm_With_Deep_Sleep, which is in Advanced->DeepSleep. That example demonstrates how to use the function rtcIsSet(), which checks if the RTC was set before. You should only set the time if it wasn’t already set - otherwise you’ll overwrite it.
Check that example and see if it resolves your issue. If not, feel free to share the relevant parts of your code and I can take a look and test it.
