Does this device support CBR files? I want to use it as a manga reader.
Originally submitted via email support on 23 February 2022. Migrated to the forum for community visibility.
CBR format uses compression, which Inkplate cannot handle directly. You can convert CBR files online using a converter, then send the converted format to Inkplate. Alternatively, you can convert the files to RAW data and use that on Inkplate.
Does the same method also work with Inkplate 10?
All Inkplate models have similar code, with differences only in the e-paper driving routines. The example code works on all Inkplate devices with minor changes to account for dimension and resolution differences.
