I tried to use the U8g2_for_Adafruit_GFX library but since it needs the GFX library it conflicts with functions already included with the Inkplate GFX library and I can’t use U8g2_for_Adafruit_GFX.
Any ideas?
Originally submitted via email support on 10 December 2023. Migrated to the forum for community visibility.
Inkplate supports only ASCII characters in the Adafruit GFX library. If you need UTF-8 support, you will have to implement this yourself. A possible workaround is to render the text required to display as a monochrome bitmap image and then display that image where the text should be. It works surprisingly well.
