Inkplate web server setup and MQTT server capability
How does Inkplate set up as a webserver? Are we talking a MQTT server?
Originally submitted via email support on 5 February 2022. Migrated to the forum for community visibility.
In the example provided with the Inkplate library, Inkplate is set up as a basic HTTP server. That is a basic example of the HTTP server; if you need other functionality you can implement it on Inkplate.
Could I run a MQTT server on it?
We never tried to run the MQTT server on Inkplate but we ran the HTTP server. You could try to run the MQTT server; it should work because it works on ESP. The only problem can be with memory.
