Inkplate13Spectra buttons read out
Hello,
I have an Inplate13Spectra and want to check the status of the buttons. How can I do that in the Arduino IDE? I couldn’t find an example for this.
Thank you,
Andre
Hi @andre_goerisch
On the Inkplate 13SPECTRA, only the Wake button is available for use in your own code. You can access it at GPIO 18. Here is a simple example (without debouncing) that reads and prints its state:
#define INPUT_PIN 18
void setup() {
  Serial.begin(115200);
  pinMode(INPUT_PIN, INPUT);
void loop() {
  int state = digitalRead(INPUT_PIN);
  Serial.println(state);
  delay(200);
If you need additional buttons, you can wire them up to the expander pins instead. The code for that is available via this example.
