Hello,
I tried out the micryphton example ‘display_image_web.py’ but then I run the example I get the python error
File “”, line 6, in
File “/lib/inkplate6.py”, line 5, in
ImportError: no module named ‘inkplate’
I download the libaries from Inkplate-micropython/shared at master · SolderedElectronics/Inkplate-micropython · GitHub
But there is no file inkplate.py
I flashed the the last micropyhton firmware from the github-repository.
Where can I get the needed inkplate.py file?
Sincerly
Chris
Hello Chris,
Sorry for the late reply. The module you are describing is our user module located within the inkplate-firmware.bin file located here: Inkplate-micropython/firmware/inkplate-firmware.bin at master · SolderedElectronics/Inkplate-micropython · GitHub
Flashing said firmware and downloading all of the required modules using mpremote (as described in the README here: https://github.com/SolderedElectronics/Inkplate-micropython/tree/master#flashing-via-thonny-ide), I was able to successfully launch the example you tried.
Could you please confirm that the inkplate-firmware.bin file is the one being flashed and that all the modules are installed vi mpremote?
Thank you for the answer. I doing something wrong by installing the micropython libs.
