I have a problem with an IR sensor I purchased. I connected it as follows: with the sensor positioned horizontally and the black LED on the left, I connected the bottom two pins to ground, the other two pins to 5V, and the blue LED pin to A0. I’m using 2 IR sensors in my project and I’m wondering if the problem is that both are connected to the same 5V, so both pins receive signal from A0 and A1. The issue is that my sensors won’t turn off.
Dobar dan, imam problem sa IR senszorom koji sam kupio kod vas. Naime spojio sam senzor na sljedeći način: kada senszor postavimo vodoravno da nam je crna ledica/lampica lijevo; donja dva pina sam spojio na ground, dok sam duga 2 spojio na 5v i dodao pin sa plave ledice/lampice na a0. U projektu koristim 2 IR senzora pa sam razmišljao možda je problem u tome što su oba spojena na isti 5v pa onda oba pina dobivaju signal sa a0 i a1. Znači problem je što mi se senzori ne gase… unaprijed hvala na pomoći.
Originally submitted via email support on 13 May 2023. Migrated to the forum for community visibility.
