LCD KeyPad Shield: using ICSP connector for custom display output
I’m working on a project where I need to occasionally change a temperature value - specifically, I need to set a temperature value in the code without uploading the entire program again. For example, I want to change the target temperature for a heating element (sometimes 50 degrees, sometimes 60 degrees, etc).
Pozdrav. Radim na jednom projektu kod kojeg bi trebao ponekad promjeniti vrijednost temperature tj da nekako u kod ubacim neku vrijednost temperature a da nije upload čitavog coda ??
Npr. da mijenjam vrijednost temperature do koje će neko grijaće tijelo da grije ( nekad 50 stepeni , nekad 60 … itd ).
Nadam se da ste me razumjeli.
Hvala
Originally submitted via the contact form on soldered.com on 30 August 2016. Migrated to the forum for community visibility.
You might find this tutorial helpful: https://e-radionica.com/hr/blog/2016/03/29/podesivi-termostat-s-relejom/
pogledajte može li Vam ovaj tutorial kako pomoći: https://e-radionica.com/hr/blog/2016/03/29/podesivi-termostat-s-relejom/
That looks like what I need, but I have an LCD with buttons and there are 6 pins labeled ICSP. Can I use this connector to output values and messages that I set in the code?
To bi bilo to , samo što je u mene lcd sa tipkama i ima još nekih 6 nožica kod kojih piše ICSP , da li ovaj konektor mogu kako iskoristiti za ispis vrijednosti i poruka koje zadajem u kodu ?
Hvala
[name removed] Sofic
Is your display a TFT or LCD? Can you provide a photo? This involves serial SPI communication: http://cdn.instructables.com/FR9/HXLZ/GAPV8IA4/FR9HXLZGAPV8IA4.MEDIUM.jpg We’ll need a photo to help you with the correct library for your display.
Vaš ekran je TFT ili LCD? Može li slika.
Inaće radi se o serijskoj SPI komunikaciji: http://cdn.instructables.com/FR9/HXLZ/GAPV8IA4/FR9HXLZGAPV8IA4.MEDIUM.jpg
Ipak će nam trebati slika da Vam pomognemo oko biblioteke koju ćete koristiti s ekranom.
We found an Arduino library for you: GitHub - DFRobot/LCD-KeyPad-Shield: New library for Arduino · GitHub and a wiki page: Gravity: 1602 LCD Keypad Shield For Arduino - Seamless Integration & Versatile Functionality | DFRobot Wiki
pronašli smo za Vas Arduino library: GitHub - DFRobot/LCD-KeyPad-Shield: New library for Arduino · GitHub
i wiki stranicu: Gravity: 1602 LCD Keypad Shield For Arduino - Seamless Integration & Versatile Functionality | DFRobot Wiki
