LED strip 5050 power requirements for 12V supply
I purchased a 12V/2A power supply and have been running it with a 3m LED strip. I’m not sure of the actual power rating.
Kupljeno na e bay-u 12v /2A snaga nepoznata dosada je radio na 3 metra led trake?
Originally submitted via email support on 30 May 2016. Migrated to the forum for community visibility.
The adapter is 24W. A 5050 LED strip draws 7.2W per meter, so theoretically you can run just over 3m, and in practice probably 4m without issues. A 3A power supply would be needed for 5m of strip.
radi se o 24W adapteru. 5050 LED traka po metru ima 7,2W, dakle možete malo više od 3m upogoniti po teoriji, u praksi vjerojatno i 4m bez problema. 3A napajanje bi bilo za 5m trake.
