Li-ion battery 100mAh 3.7V datasheet with capacity-specific electrical parameters
I purchased the Li-ion battery 100mAh 3.7V (SKU 333276). The attached datasheet is incorrect and provides no relevant technical specifications for this battery. I need the correct datasheet urgently.
Originally submitted via email support on 20 November 2025. Migrated to the forum for community visibility.
The datasheet we have for this battery is the same one used for all our Li-Ion batteries, with only the dimensions and capacity differing. The closest technical details available are at: https://soldered.com/productdata/2020/07/Soldered_500-mAh_datasheet.pdf
I can also make a request to get the 1:1 datasheet specific to the 100mAh battery.
The 500mAh datasheet helps, but with a change in capacity, other factors change as well: charging current, discharging current, and maximum fast charging current. These parameters are critical for my use case and testing. I’m requesting the 1:1 datasheet for the 100mAh battery as quickly as possible.
Here is the datasheet for the 100mAh battery.
Attachment omitted in migration: datasheet-100mah-601220 .pdf
