Li-ion Battery 5000mAh 3.7V parallel connection safety
Can two Li-ion Battery 5000mAh 3.7V (SKU 333288) units be connected in parallel?
Original message (Serbian)
Imam jedno pitanje: dali se može uzporedno vezati dve Li-ion baterije 5000mAh 3.7V (SKU: 333288)?
Lep pozdrav,
Originally submitted via email support on 28 May 2025. Migrated to the forum for community visibility.
We do not recommend any modification to our batteries for safety reasons, and connecting them in any way other than as designed is not supported. While batteries in general can be connected in parallel, these units have a protection chip that could react incorrectly with parallel connection. We recommend using a battery with higher capacity instead.
hvala na upitu, ne preporučujemo ikakvu modifikaciju naših baterija zbog sigurnosti i spajanje na bilo koji drugi način osim predviđeno. Baterije se inače mogu spajati u paralelu ali ove imaju na sebi chip za zaštitu koji bi mogao krivo reagirati uz paralelno spajanje. Preporučujem uzimanje baterije s većim kapacitetom.
