Do you have a datasheet for the Li-ion battery 900mAh 3.7V? I’m working on a project and need information on its internal resistance, output voltage, and maximum output current as a function of charge percentage.
biste li mi mogli poslati tehnička uputstva (datasheet) za proizvod kojeg prodajete imenovan “Li-ion battery 900mAh 3.7V”?
S njim radim jedan projekt i želim uvid u njegov unutarnji otpor, izlazni napon i maksimalnu izlaznu struju u ovisnosti o postotku napunjenosti.
Originally submitted via email support on 23 November 2025. Migrated to the forum for community visibility.
We have a material safety data sheet that applies to all our Li-Ion batteries: https://soldered.com/productdata/2022/12/Soldered_MSDS.pdf
I’ve requested a datasheet for this 900mAh variant. We’re currently updating all product documentation, and I’ll get back to you with the exact datasheet once it’s available.
imamo ovaj material safety data sheet koji vrijedi za sve naše Li-Ion baterije: https://soldered.com/productdata/2022/12/Soldered_MSDS.pdf
Napravit ću zahtjev za datasheet za ovu od 900mAh, baš smo u procesu ažuriranja svih sadržaja uz proizvode. Javim se putem ovog ticketa uskoro kad dobijem točan datasheet pa proslijedim.
