Load Cell Module 100kg dimensions and mounting points vs 120kg
I have several questions about the Load Cell modules (120kg). Is it possible to source smaller modules as well (for example, 60kg, but with smaller dimensions)? Also, I see you’ve had these in your product range for a while now. Do you always keep larger quantities in stock, and how quickly can you reorder them when they sell out? For example, I would need 1 unit for testing physical dimensions and everything (I’ve been working with a 20kg module so far), and then I would need 5 units if the physical fit works in my product. After that, I would also need multiple units at once if everything passes testing.
surađivali smo već ranije ( Putem Zajednice tehničke kulture Valpovo-Belišće) Imam nekoliko upita u vezi sa Loadcell modulima (120kg). 60kg, ali manjih dimenzija) Primjerice, trebao bih kupiti 1 komad za testiranje fizičke veličine i svega ( sada sam radio sa 20kg modulom) , a potom bih trebao 5 komada ako uštimam fizički u proizvod. Nakon toga također više komada odjednom ako sve OK prođe.
Originally submitted via the contact form on soldered.com on 20 August 2018. Migrated to the forum for community visibility.
Currently we source load cells of 2kg, 10kg, and 50kg in addition to the 120kg currently in our range. The 120kg will be kept while stocks last and will then be replaced with 100kg load cell modules. However, if you need 120kg load cell modules in quantities larger than 50 units, we can source them again. We currently have 20+ units in stock.
hvala Vam na upitu! 120kg ćemo imati dok traju zalihe te ćemo ga nakon toga zamijeniti s 100kg load-cell modulima. No ipak, ako budete trebali 120kg load-cell module u količinama većim od 50kom, moći ćemo ih opet pribaviti. Tako da, ne bi trebalo biti problema :slight_smile: Javite ako imate još pitanja!
Just one more question: are the dimensions of the 100kg modules you’ll be selling later the same as the 120kg ones, or at least similar? What about the mounting points compared to the existing module, since my entire product design is based on that?
Hvala ljepa na odgovoru. Zanima me samo jos je li dimebzija ovih modula od 100kg koje cete kasnije prodavati ista kao kod ovih od 120kg ili barem priblizna e kakve su točke za montažu u odnosu na ovaj postojeći modul budući da se cijeli proizvod bazira na tome.
Hvala unaprijed.
I can share the dimensions for the module we’re expecting, but it’s not 100% certain it will be identical. I understand why that’s important to you, but unfortunately I can’t provide more information at this point.
šaljem Vam dimenzije za modul koji očekujemo, ali nije 100% sigurno da će biti taj identičan.
Attachment omitted in migration: Screen Shot 2018-08-21 at 11.42.36.png
