LTR-507 connecting multiple sensors on one ESP32
How do I connect multiple LTR-507 sensors, for example 10 units, and set a separate I2C address for each sensor? I’ve already figured out how to set up one sensor. I previously did this with VL53L0X and want to compare precision using the LTR-507 instead. I’m planning to build a product counting system for a production line with 4-6 items in the queue at a time.
Kako povezati npr. 10 kom, kako postaviti zasebnu I2C adresu za svaki pojedini senzor? za 1 senzor mi je jasno, to sam napravio.
sa VL53L0X sam to napravio, zanima me kako sa LTR-507 napraviti to isto pa da usporedim preciznost.
Namjera je da napravim sustav za brojanje proizvoda na proizvodnoj traci, kojih bude od 4-6 komada u liniji.
Hvala !
Originally submitted via email support on 10 February 2024. Migrated to the forum for community visibility.
You can select different I2C addresses using the JP3 jumper on the board. This breakout supports 3 different I2C addresses. Attach the board schematic and a screenshot from the datasheet showing how to use JP3.
If you have any I2C issues, it’s a good idea to use the I2C scanner sketch, which will always show you which devices the microcontroller finds on the I2C line: Soldered-Hacky-Codes/I2C_Scanner/I2C_Scan/I2C_Scan.ino at main · SolderedElectronics/Soldered-Hacky-Codes · GitHub
u prilogu ti šaljem sjemu za ovaj breakout kao i ovaj screenshot iz datasheeta. U njemu možeš vidjeti kako možeš koristiti JP3 na boardu kako bi izabrao adresu. Možeš birati između 3 različite I2C adrese za ovaj breakout.
Ako imaš nekih problema sa I2C-om, super ideja je koristiti I2C scanner sketch koji će ti uvijek ispisivati koje uređaje mikrokontroler pronalazi na I2C liniji: Soldered-Hacky-Codes/I2C_Scanner/I2C_Scan/I2C_Scan.ino at main · SolderedElectronics/Soldered-Hacky-Codes · GitHub
Nadam se da je ovo informativno i da ti pomaže u razvoju tvog projekta, koji zvuči dosta zanimljivo.
Attachment omitted in migration: Digital light & proximity sensor LTR-507 breakout Schematics.pdf
Thanks for the quick reply. If I understand correctly, it’s still not possible to connect 10 sensors to a single ESP32, only 3 sensors?
Hvala na brzom odgovoru, ako sam dobro shvatio, ipak nije moguce spojiti
10 kom na jedan ESP32 , nego samo 3 kom.
Jel to tako?
You can use additional pins to create another I2C interface on the ESP32. Here’s an example of how to do this: ESP32 I2C Communication: Set Pins, Multiple Bus Interfaces and Peripherals | Random Nerd Tutorials section “ESP32 Using Two I2C Bus Interfaces”
Another good option is an I2C multiplexer: I2C multiplekser TCA9548A - breakout pločica s 8 kanala za Arduino – Soldered Electronics Check the description - I think that’s exactly what you’re looking for.
Možeš koristiti druge pinove za još jedan i2c interface, evo primjera kako to raditi sa ESP32: ESP32 I2C Communication: Set Pins, Multiple Bus Interfaces and Peripherals | Random Nerd Tutorials sekcija “ESP32 Using Two I2C Bus Interfaces”
Još jedna dobra opcija je I2C multiplexer: I2C multiplekser TCA9548A - breakout pločica s 8 kanala za Arduino – Soldered Electronics Pročitaj opis, mislim da je to točno to što tražiš.
