I purchased easyC cables yesterday to connect the GPIO expander MCP23017 (which I previously bought from you) to reduce wire clutter.
The built-in easyC connector is NOT connected to the VCC, SDA, and SCL pins. It is only connected to GND.
I checked both modules with a meter across all 4 connectors and found the same issue on all of them.
I also checked your website and this module is listed as compatible with the easyC standard, so the pinout should be VCC, GND, SDA and SCL - or am I mistaken?
The module works fine when I connect it directly to pins, but does not work when I connect it via the easyC connector.
I have attached a photo. Green shows connectivity and red shows no connectivity.
Kupio sam jučer easyc kabele za spajanje GPIO expandera mcp23017 (koje sam prethodno kupio kod Vas) kako bi „umanjio žičani kupus“
Naime, ugrađeni easyc konektor NIJE spojen sa pinove VCC, SDA i SCL. Spojen je samo na GND.
Provjerio sam oba modula instrumentom, odnosno sva 4 konektora i ista je stvar.
Provjerio sam također i na vašoj stranici i taj modul je kompatibilan sa easyc standardom te bi mu pinout trebao biti VCC, GND, SDA i SCL ili ja nesto grijesim ?
Modul uredno radi kad ga spojim na PINove, a ne radi kad ga spojim preko easyc konektora.
Slika je u prilogu.
Zelenom bojom ima connectivitija, a crvenom nema.
Molim za pomoć.
Poz
Tnx [name removed]. Nisam ni skuzio te jumpere s prednje strane do jucer kad sam to vec rijesio.
Poz
From: [name removed] (Generalni kontakt: e-radionica.com) [mailto:[email removed]]
Sent: Tuesday, August 02, 2022 7:52 AM
To: [name removed] - [name removed] d.o.o
Attachment omitted in migration: easyc.jpg
Originally submitted via the contact form on soldered.com on 6 September 2022. Migrated to the forum for community visibility.
