MCP23017 library won't compile in Arduino IDE
I’m unable to compile blink.ino with the MCP23017 library.
Attachment omitted in migration: Error message Soldered blink 071125.txt
Originally submitted via email support on 7 November 2025. Migrated to the forum for community visibility.
We were able to compile this on Dasduino CONNECTPLUS, ESP32 dev module and Inkplate board definitions. You need to install the library in your /libraries folder in documents/Arduino, not just in your project folder. This library also uses easyC.hpp internally.
The Arduino compiler requires specific directory structure. Install the library in /libraries and then try File > Examples > Soldered MCP23017 Arduino Library > Blink.
