MH-Z19C-DZ sensor 5V power with easyC JST cable compatibility
I saw you have an easyC to breadboard pin connector that you say is compatible with JST and has 4 pins. The only issue is that easyC is made for 3.3V, but this sensor needs 5V.
vidio sam da postoji vas konektor easyC u breadboard pinove koji po vasem je kompatibilan sa JST i ima 4 pinova jedina stvar je sto je easy C napravljen za 3.3V ,a senzoru treba 5V
Originally submitted via email support on 1 April 2025. Migrated to the forum for community visibility.
easyC uses JST-SH compatible connectors with 1.00 mm pitch between pins, often called JST 4-pin connectors. The footprint for the female connector on a PCB can be found here, and for the male connector on a cable here.
It is a 4-pin JST, not 7, and unfortunately we don’t have a variant for 7.
je li ovo taj koji misliš https://soldered.com/product/easyc-cable-with-female-headers/
Naši easyC senzori su 3V3 na easyC kabliću da, detalji za easyC konektor su sljedeći:
EasyC koristi JST-SH kompatibilne konektore s razmakom između pinova od 1,00 mm, često nazivane JST 4-pinskim konektorima. Crtež za ženski konektor na PCB-u možete pronaći ovdje, a za muški konektor na kabelu ovdje.
On je 4-pinski JST, ne 7, na žalost nemamo varijantu za 7.
