What is the maximum video resolution and frame rate supported by the Micro HDMI to HDMI cable 1m (SKU 100360)?
Koju najveću rezoluciju video signala (i uz koji frame rate) podržava Vaš Micro HDMI na HDMI kabel 1m (SKU: 100360)?
Hvala, pozdrav!
Originally submitted via email support on 16 May 2023. Migrated to the forum for community visibility.
The Micro HDMI to HDMI cable (SKU 100360) should support 4k resolution at 60 fps without issues. HDMI has no technical limit on which resolution it can support, and this cable is not excessively long so there should be no signal degradation.
Micro HDMI na HDMI kabel (SKU 100360) bi trebao bez problema podržavati, primjerice, 4k rezoluciju po 60 fps. HDMI nema tehnički limit koju rezoluciju može podržati, i ovaj kabel nije pre dugačak pa ne bi trebalo doći do kvarenja signala i zbog toga.
