Mini pumpa za vodu power consumption in watts
I need to know the power consumption in watts for this pump. If you don’t have a datasheet, that specification alone would be sufficient.
Ako nemate datasheet, sami podatak kolika je Snaga u wattima bi bila dovoljna.
Originally submitted via email support on 27 August 2024. Migrated to the forum for community visibility.
We don’t have a datasheet for this generic pump. You can measure the power consumption yourself. If you have a multimeter, you can measure the current it draws while running. For example, if you supply 5V and measure a current of 1A, then the power is 5W.
Na žalost nemamo datasheet za tu generičku pumpu. Snagu možeš izmjeriti sam. Ako imaš multimetar, možeš izmjeriti struju koju vuče dok radi. Ako joj npr. daješ napon od 5V i izmjeriš struju od 1A onda znači da je snaga 5W.
Nadam se da je ovo bilo informativno :slight_smile:
