Mini water pump power supply options for 3-6V operation
Can you supply something for powering the mini water pump at 3-6V?
Original message (Serbian)
Pozdrav, Moliću lepo za odgovor da li se kod Vas može kupiti nešto za napajanje od 3-6V Srdačno S
Originally submitted via email support on 1 April 2023. Migrated to the forum for community visibility.
The Mini water pump needs to be connected to 3-6V DC power. The pump operates immediately when connected to power. To get power for the pump (optimally 5V DC), you can use a mobile phone charger.
We offer various power adapters that output 5V:
  • 5V 3A 15W power supply with USB-C outlet
  • 5V 3A 15W power supply with microUSB connector
  • 5V 2A 10W power supply with USB outlet
For your case, you would need to cut the power cable from one of these options and solder it directly to the pump.
Ukoliko je riječ o Mini pumpi za vodu, istu je potrebno spojiti na napon 3-6V DC. Pumpa sama po sebi, radi čim se spoji na napon. Kako biste dobili napon za rad pumpe (optimalno 5V DC) možete koristiti punjač za mobilni telefon. Napajanje 5V 3A 15W s USB-C izlazom Napajanje 5V 3A 15W s microUSB konektorom Napajanje 5V 2A 10W s USB izlazom U Vašem slučaju, kabel napajanja s prethodno navedenih linkova trebalo bi prerezati te direktno zalemiti na pumpu. Sve artikle koji se nalaze iznad u poruci, moguće je naručiti na našem webshopu.
