I’m working on a final year project using Croduino to measure liquid level in a container. My plan is to use a pressure sensor to read the pressure via Arduino, then calculate the liquid height using a physics formula and display the level on an LCD screen. I found your pressure sensor, but concluded that its measurement range is too large for my needs. I need a range of approximately 0-5 kPa, possibly slightly higher, but not much more. Is this the only measurement range your pressure sensor offers? If so, do you have any similar sensors in stock that I haven’t found, or can you recommend other vendors or any information that might help?
Originally submitted via email support on 25 August 2017. Migrated to the forum for community visibility.
