MQ3 Sensor always reads 1023 with Arduino
I’m using an Arduino to read analog data from the MQ3 sensor. When everything is wired, the sensor always reads 1023, which is the highest possible value. I tested with alcohol vapors but the reading didn’t change, and the LED that should turn on didn’t light up either.
Originally submitted via email support on 3 April 2024. Migrated to the forum for community visibility.
I tested the sensor and it works correctly for analog reading on a Dasduino Core. It reads PPM 0 but the voltage does change. Which microcontroller are you using? Are you using the native->MQ3 example from our library?
