MQ7 Gas Sensor CO ppm calibration method
I have the MQ7 gas sensor. Do you know of a way to calibrate it to get approximate ppm CO readings? The datasheet is unclear on this. For comparison, the MQ135 sensor has straightforward calibration and examples are available online, but I cannot find the same for this sensor.
nastavno na prošli mail,
Ova komponenta:
https://e-radionica.com/hr/mq7-senzor-plinova.html Znate li za neki način za kalibraciju istoga da bi se dobio (približni) ppm CO plina? U datasheetu je dosta nejasno. Recimo kod senzora MQ135 je jednostavna kalibracija i može se naći online, za ovaj senzor ne mogu naći.
Hvala unaprijed,
Originally submitted via the contact form on soldered.com on 16 February 2021. Migrated to the forum for community visibility.
The MQ series sensors are not capable of delivering precise ppm readings. They should be used more as an indicative factor of particles in the air, providing a qualitative measure of CO levels rather than numerical values - for example: low, medium, high.
nažalost ne, predlažem Vam da od MQ serije senzora ne očekujete precizna ppm očitanja, s obzirom da oni to nisu sposobni izbaciti. Trebali bi se koristiti više kao orijentacijski faktor čestica u zraku koji bi mogao označavati s količinom CO u zraku koja nije brojčana, npr: malo, srednje, visoko.
