NO gas sensor breakout schematic and I2C level shifter design questions
I’m working on a research project to design a low-cost Nitric Oxide Generator for medical use. This sensor breakout board is very close to what I was planning to design for implementing closed loop control.
I have a few questions:
  1. Do you have a time frame for availability for this unit?
  2. Can you supply the breakout board only as I have an SGX 4NO 250 sensor already
  3. If the breakout board is not available, is it possible you could please provide the board schematic and Gerber file so I can get the PCB made? I was planning to use a LPM91000, but with only an I2C interface.
Originally submitted via email support on 21 November 2025. Migrated to the forum for community visibility.
Here are the KiCad hardware files and the gerbers. We had a product which was a board like this without the sensor but we are looking to improve the design at this time. The hardware files should help with your project.
Attachment omitted in migration: electrochemical gas sensor.zip
Attachment omitted in migration: Electrochemical gas sensor breakout 190x202 25 gerber.zip
I’m organizing the production of a couple of boards for my research project.
I do have a few questions:
  • What chip do you use for the I2C (U4) level shifter?
  • I noticed in the design the U4 pins 2 and 5 both receive 3.3v, is this correct?
Attachment omitted in migration: U4 schematic.png
On U4, the part is l2N7002SDW1T1G - it’s a generic component, a dual NMOS. The reference package is SOT-363.
Yes, pins 5 and 2 are correctly connected to 3v3.
Hello, could you reupload these files please? Thanks in advance.
