Hi, I ordered the NULA DeepSleep ESP32-S3 with male pin headers. Are the pins already soldered onto the board? If not, could you solder them facing downwards so I can plug the board into a breadboard?
Do you have 4.7 kΩ in your resistor set?
Thanks!
Hello @branimir_rajcic65,
If you buy the variant labeled “Male Pin Headers”, the headers come pre-soldered and they are facing down so that it can be connected onto a breadboard.
In the image below, you can see all of the resistors included in the resistor kit, each value has 20 resistors included:
Best regards,
JosipKuci
