NULA DeepSleep ESP32-S3 Qwiic Pin Numbers
Hi,
I would like to use the Qwiic connector for non i2c communication. As such I’m assuming the SDA and SCL lines are connected directly to pins on the ESP32-S3 module. What I would like to know is what are the GPIO pin numbers for these connections on the ESP32-S3 so I can address in them in code with normal digital on/off logic.
Hello orders,
Sorry for the late reply. The Qwiic connector is wired directly to pins IO8 (SDA) and IO9 (SCL)
