I received the filament and tested it - very satisfied. Have you printed nylon on a Prusa i3 MK3? I have the same printer and am planning to print nylon.
Primio sam filament i isproba,jako sam zadovoljan:-). Dali ste printali mozda najlon na Prusa i3mk3, naime imam isti pa planiram printati i najlon
Originally submitted via the contact form on soldered.com on 18 October 2018. Migrated to the forum for community visibility.
We’re glad to hear you’re satisfied! We did test print nylon - on the same printer, as it happens. Like any nylon, you need to know how to get nylon to adhere to the bed, but otherwise it goes very smoothly. The strength is excellent. It’s also important to keep nylon in a well-sealed bag after opening.
drago nam je čuti da ste zadovoljni!
Napravili smo test print Nylona - naravno. I to baš na istome printeru! Kao i svaki nylon, treba znati kako da se nylon zalijepi za bed, a ostalo ide vrlo glatko. Čvrstoća je vrhunska. Važno je također Nylon držati u dobro zatvorenoj vrećici nakon otvaranja.
Is adhesive needed on a coated steel sheet for nylon printing?
Dali je potrebno ljepilo na coated steel sheet za print najlona?
No, we successfully printed without it.
Ne, mi smo uspješno printali bez.
