I have a question about charging a battery with the PowerBooster. The connector is not compatible. Does this mean I need to solder a different connector, or is there a better solution?
Pozdrav, još jedno pitanje na ovu temu punjenja baterije PowerBoosterom, priključak nije kompatibilan. Znači li to da moram lemiti drugačiji priključak ili postoji neko bolje rješenje?
Originally submitted via the contact form on soldered.com on 24 April 2017. Migrated to the forum for community visibility.
The PowerBooster has a JST connector built in, so it should be compatible with batteries.
koliko vidim u specifikacijama PowerBooster ima ugređen JST konektor, tako da će odgovarati baterijama.
It’s possible that there are JST connectors on both sides, but in the attached image you can see the difference between the two connectors. The battery connector is 30-40% smaller. Do you have any ideas how the problem could be solved?
moguće je da se radi o JST konektorima na obje strane, ali u prilogu mozete vidjeti razliku između dva konektora, konektor baterije je 30-40% manji. Imate li ideju kako bi se problem mogao riješiti?
Attachment omitted in migration: IMG_0221.JPG
I see the difference. We will send you two connectors that will fit the charger.
vidim razliku. Šaljemo Vam danas dva konektora koja će odgovarati punjaču.
