How do you program the PICO and DAMBA models? I also have a BASIC2 and NOVA. I cannot find information on the blog. I see only that they must be programmed via an external programmer (for example, BASIC). If I understand correctly, on BASIC2 you could connect PICO or DAMBA and program them that way. If so, could you provide some materials if you have them, or at least a connection diagram?
Kako se programiraju modeli PICO i DAMBA.
Uz njih imam i BASIC2 i NOVA.
Na blogu ne mogu pronaći info. Vidim samo da se moraju programirati preko externog programatora (npr, BASIC).
Ako sam dobro razumio, na BASIC 2 bi se moglo “uštekati” PICO ili DAMBA i na taj način ih programirati.
Ako je tako molio bih nekakve materijale ako imate ili barem shemu spajanja.
Hvala,
Originally submitted via email support on 4 March 2016. Migrated to the forum for community visibility.
